93 Winnebago Elante
4621racing
Can't find the convertor book says under clothes closet but not there . switch to 110 outside sorce thumps but batteries are dead and they are new, any help Thanks Jimmy
15 REPLIES 15
4621racing
J-Rooster, that is where it is gound it cooked under oven and 12 volt push breakers 12 volt is on other side up over dinette.I have searched the MH over on pass side to no avail will order a new one tomorrow.old one is 7940 40 amp and co that made it is gone. THANKS YA'LL Jimmy
J-Rooster
Jimmy, the converter in my Winnebago is under the drawer that is under the oven. In most RV's that I seen the converter is always not very far from the batteries.
MrWizard
Moderator
Moderator
If your dc fuse panel is any where below waist height
You will find the converter section is behind the fuses
Unplug shore power, disconnect batteries
Remove fuse panel to access converter
Unless you have a blown main charge/battery fuse the converter charge section
No battery power sounds like the main battery charge fuse is bad
Are batteries charged or dead
Did you have power lights that slowly went dead?
If so fuses are good , converter is bad
I can explain it to you.
1997 F53 Bounder 36s
1995brave
The converter is probably in the same cabinet as the AC circuit breaker/DC fuse panel, just remove the lower panel and you should see the transformer.
BobR
It should be by the passenger side rear wheel well (aft) which is under the dinette and jacket closet in main aisle. There is a vent cover near the floor to gain access.
Mile_High
Post pics of that Elante ๐Ÿ™‚ Those were cool MHs
2013 Winnebago Itasca Meridian 42E
2013 Jeep Wrangler Unlimited Sahara Towed
enblethen
Winnebago
Winnebago has some good wiring diagrams at their website. Not sure of your model, but this may help.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
enblethen
Have you tried cycling the battery disconnect switch?
Did you look for fuse or circuit breaker adjacent to the batteries?
Do you have a volt meter?
Adjacent to the 120 volt circuit breakers should be a small plate covering the 12 volt DC fuses. have you checked them?
Bud
USAF Retired
Pace Arrow
usersmanual
-under the fridge- under the bed- in a lower compartment- keep looking as its there somewhere and obviously not pluged in or NFG?
23 years old- most likely died by now
4621racing
Have reset all breakers in rear by bed (AC) and all pop out breakers over dinette all felt good . will take panel above dinette out and see if convertor is back there ,Thanks batt not hooked up backwards all cables were marked. Jimmy
4621racing
Yes THUMP is ATS working. the on /off on dash could be bad I never use it but could be bad, can't fing convertor. Thanks Jimmy
Old-Biscuit
First find MAIN DC Dist Panel......has all the 'house' DC Individual circuit Fuses
Close by/behind it/next to it would be the converter
Question.....
Whenever I read 'new batteries' I have to ask
Did you mark battery cables prior to removal, if not did you trace battery cables prior to connecting to new battery.
If connected backwards.......'reverse polarity' fuses (30A or larger on converter) blow to protect converter electronics
If blown ---no DC from battery OR from converter when on AC
enblethen
Transfer switch. Possibly mounted to the back of power distribution panel.
Check for circuit breaker adjacent to the batteries.
possibly battery disconnect in disconnected mode or bad. Try turning them off then back on.
Bud
USAF Retired
Pace Arrow
wolfe10
gbopp wrote:
What thumps?
Perhaps he is hearing the ATS (Automatic Transfer Switch) latch in-- just a guess.
Should be able to track down the source of the "thump".
Brett Wolfe
Ex: 2003 Alpine 38'FDDS
Ex: 1997 Safari 35'
Ex: 1993 Foretravel U240
