TheCoach's avatar
TheCoach
Abs Sensor Replacement
Is it possible to remove and replace the rear wheel sensor without taking off everything down to the brake drum? This is the Meirtor Wabco pneumatic system I know the manual says that you are supposed to remove both rear wheels and the brake drum. It would appear that once you remove the rubber grommet and the spring loaded retainer clip that the sensor would come out. I know it sounds too simple but I just had to ask. :@
Thanks in advance
Robert
