gja1000's avatar
gja1000
AC only has 1 speed, low, compressor not kicking on
Our new Coachman Class C AC is only running on low speed with very little air output, and the compressor is not kicking on. It did this one other time when we tripped the GFI, but as soon as we reset the GFI the AC was back at full speed. This time the AC went to low speed in the middle of the night, so no GFI trip. Any ideas?
  • Interesting... The GFI shouldn't effect the Air Conditioner. It's on it's own separate breaker. You may have a wiring issue (is it under warranty?).
    We had an issue with the low speed fan, and it turned out that the rotary switch had gone bad. Got a replacement on eBay for less than 20.00, and it was easy to replace.
