garymunson
May 24, 2016Explorer
Adding Solar Charger
Am I correct the only proper way to add a solar trickle charger is to run a wire all the way to the house batteries? I would think I need to be on the 'battery side' of the coach battery disconnect relay. If not, turning off the coach batteries would also disconnect the charger. Wish Winnebago had prewired that.
