Danford50 wrote:
when I check the status of my battery at the panel it show full, when I am plug into shore power at home the inverter show 8.9 and a error code of 2 (which mean low voltage) do I need to replace my battery or do I have another problem?
Is that backwards? On shore power, your panel will show "full" if the converter or inverter/charger is working right, because the panel is just a rough voltmeter set to show "full" if it sees about 12.7 volts or higher, and the converter will be higher ( in the 13s) It will show full even if the battery is dead.
EDIT--I am not sure about the situation AJR above mentions--if the battery is shorted or whatever and not just "dead".
Meanwhile, off-grid and on inverter, which runs off the battery, it will not work if the battery "loaded voltage" is below 10.5 volts ( the inverter alarms at 11 volts typically, but keeps running to 10.5v--that is to protect the battery from being dragged down even lower)
When the inverter shuts down at 10.5 "loaded" the battery voltage should bounce back to say 12v or whatever "unloaded" voltage, so you can keep camping for a little while, but no inverter until the battery gets some recharge.
So, if the inverter is saying 8.9v and won't run, the battery must be nearly dead. It might recover with a proper recharge and recondition session. Or not.
1. 1991 Oakland 28DB Class C
on Ford E350-460-7.5 Gas EFI
Photo in Profile
