Aug-26-2016 08:02 AM
Sep-11-2016 01:40 PM
jgellis586 wrote:
Finally have tv mounted. Mounted bracket to half inch board and mounted to side wall of opening which were solid. Trying to figure out how to post picture which will clarify.
Sep-11-2016 10:12 AM
Aug-26-2016 10:50 AM
Aug-26-2016 09:41 AM
Aug-26-2016 09:27 AM
Aug-26-2016 09:01 AM
Aug-26-2016 08:48 AM
jgellis586 wrote:
Thanks for the quick reply. It has the opening for the tv and the connections in fact I have the tv hooked up to make sure it works. The wall just does not feel robust. Might have to drill a pilot hole to see what it is like.
Aug-26-2016 08:23 AM
Aug-26-2016 08:10 AM
jgellis586 wrote:
Been lurking for 4 years and just purchased a 2017 Thor four winds 28z. Question I am planning on mounting a tv in bedroom but the wall seems flimsy. What would be the best way to mount? Looks like screws or bolts will protrude through bathroom cabinet. I am planning to use washers or a block of wood to add additional support. Will this work and what have you done to mount the tv.
Thanks in advance for your help.
