k6dcp's avatar
k6dcp
Best way to stop cabinet door rattle?
My IVan has only one fault -- a rattle that will drive you crazy after you've heard it for hundreds of miles.
I think I've localized it to the curved cabinet by the sliding door, where the "kitchen" is. That cabinet has two doors. The left door seems to be fine. The right door has a catch at the top and appears to be slightly "sprung" in that the bottom of the door does not touch the frame of the cabinet. There seems to be about a quarter inch (guessing) gap between the bottom of the door and the cabinet frame.
I tried taping the two doors together with strips of blue masking tape to see if this is the problem. Unfortunately, the desert air dried the tape and it popped off fairly quickly.
I've thought of putting industrial-strength velcro to hold the cabinet door on, or a magnetic catch, or padding the gap with foam weather stripping.
But then it occurred to me that I'm not the only one, and far from the first one, with a rattly cabinet, and that you might have solved this problem before me. If so, would you please share your solution with me?
As always, thanks for your assistance.
  • Handbasket wrote:
    I found a sheet of self-adhesive felt dots a WalMart some years ago. Dunno if they have them now. There were several sizes, all round, tan in color. It was in the same area as the picture-hanging stuff. I applied one small one to each corner of lose doors.
    Jim, "Mo' coffee!"
    Yep, and they still have them in different sizes.
  • I used small strips of Velcro. Not only did it stop the rattle, but kept everything from opening up on corners etc. get the good stuff not the cheap stuff.
  • I had the same issues you have and tried a lot of the things above. The best I found was to use the felt stick on pads they make for the bottom of chairs etc. when you have hardwood floors, you can cut them to size easily,the sticky is better than the regular door bumpers and they are thicker, which works better. I put one on the top and bottom of door and the adjust the latch a little snug. This keeps pressure on the door at all times and rattle goes away. My unit is 18 years old and people ask me how is it so quiet. Of course most of my friends are deaf.......but.
    Good luck.
  • I used some of these Cabinet Bumpers. My friend's husband used to build cabinets for a living (he ran two cabinet shops too) so I had him doing a little repair work on my RV's cabinets. He sent us down to pick up a package of these bumpers because mine seemed to have all disappeared. I know they were there at one time because the sticky residue was still there. Now all my cabinets close so quietly. I also used a few on the bottom of my butter bell.
    Jim, "Mo' coffee!"
    Hi, Handbasket!
    Probably any craft store, such as Michael,s, would have these as well...
  • I found a sheet of self-adhesive felt dots a WalMart some years ago. Dunno if they have them now. There were several sizes, all round, tan in color. It was in the same area as the picture-hanging stuff. I applied one small one to each corner of lose doors.
    Jim, "Mo' coffee!"
  • Cabinet makers use clear stick-ons called fish eyes to stop cabinet doors from banging.
  • I have quieted a lot of noises with foam weather striping. Try first by taking some sponge and wedging it into the gap. Drive and see if you hear the noise. If it is quiet, use the weather striping. You may need to use more than the glue that it comes with if the dessert air keeps if from holding.
    At least you located this noise. We have one banger that we can't locate and just put up with the bang bang when the roads get rough. Another sounds like a platter wobbling - sometimes there and sometimes not. One day I will find those suckers and quiet them.
  • How about when you travel put a piece of pipe insulation on the edge of the door that hits. Gray pipe insulation is slit down the middle and should the edge of the door should fit in it.
