Geocritter's avatar
Geocritter
Big block V8’s and premium gasoline
Has anyone here bumped the timing on their Ford 460 V8 for better performance? I realize that doing so probably necessitates the use of higher octane gasoline, but is the added performance and potential fuel mileage gain worth it? If so what was the timing changed to?
I only ask this question because of my experience with a 1989 Jeep Cherokee my son once owned. The straight 6cyl 4.0 engine was equipped with an anti-knock sensor that automatically retarded the spark. It worked but retarding the spark had a terrible effect on both the cars performance and gas mileage. For example you were normally hard pressed to average 20mpg range highway (the car had a 5-speed standard with a 3.07 axle ratio, not the normal 3.58 axle ratio). On a trip to college, towing a twin axle U-Haul trailer using premium gasoline the car got 25mpg!
Steve
