wa8yxm
Jan 17, 2020Explorer III
On my class A the dash radio is a Pioneer.. Now out of the box it does not have this feature. In my first towed. The replacement dash radio (the original died of old age) was a Kenwood. it too did not have this feature out of the box.
On both of them I plugged a box into the port on the backside and instant LINE IN. (AUX in) note there are several plug ins like a multi cd changer and XM-Radio but I plugged in an AUX in.
Play Cassette tape. CD or MP3's or portable radio (Though why you'd do that I don;t know) through the system.
Note that most modern Dash radios have one of the following options.
Blue tooth (Connect your Streaming device direct to the dash radio/system(
Aux in (native)
Aux iu (Add on like mine)
NOTE also when using AUX in I have to either use an inverter and wall wart to keep Phone charged or let it run on battery Using a 12 volt type charger will cause all sorts of **** on the audio feed (Ground loop issues)
IN my current car (Factory original radio/Cassette) I use a cassette adapter This looks like a tape but with a cord coming out that plugs into the streaming device.
Works great. I get the full power of the dash radio system while I listen to say Kingston Trio performing the Ballad of the Shape of Things Caution. the first time you listen to that track DO NOT BE DRIVING.
Aux in (native)
38,766 PostsLatest Activity: Jan 10, 2026
