cable TV
clinedinstjt
trying to watch cable tv. having problems trying to view. over the air works fine,but having problems trying to hook up to cable. is there a switch I need to change to get cable. 2015 mountain aire 4501 with all the bells and whistles. thanks
7 REPLIES 7
old_guy
there is also a place in the tv menu to switch over from air to cable so you tv reads the proper signal
clinedinstjt
thanks for all the help. Found the switch
clinedinstjt
Thanks for all the help. Found the switch
Johno02
Really good picture that presents the best vies of the facts. Pity how many people can't read it.
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
RoyB
I always thought this was a neat pictorial on how the WINEGARD WALL PLATE works...
When watching from the CABLE TV PORT you will need to make sure the PUSHBUTTON shown above is OFF (No light ON)...
Roy Ken
Roy - Carolyn
K9PHT (Since 1957) 146.52M
2005 Flagstaff 8528RESS
Sandia_Man
On most rigs simply connect coax from RV park cable to exterior coax input and connect coax from interior cable output to rear of TV, lastly TV antenna booster must be turned off for cable tv signal to pass through.
Dutch_12078
There may be a switch that turns off the power injector for the OTA antenna that also switches between the antenna and cable inputs to the TV. Hopefully someone with a similar RV model will be along that can help with locating it.
Dutch
2001 GBM Landau 34' Class A
