Jun-11-2012 11:57 AM
Jun-11-2012 02:37 PM
Brian in Michigan wrote:
Did you change the fuel filter on the frame rail?
I had the carb on mine rebuilt last year. Out in California you should not have any problem finding a rebuilder. By getting mine rebuilt and the distributor recurveddistributor recurved it made a world of change power wise.
Jun-11-2012 01:46 PM
Jun-11-2012 12:45 PM
1995brave wrote:
There is also a fuel filter on the inlet to the carb. Did you change that one also and did you put it in the right way?
Jun-11-2012 12:39 PM
Jun-11-2012 12:19 PM
lamoz wrote:
My 86 winni, has been giving me problems where it started by it shutting down on me..It lacks fuel to the engine. I've research it a bit and suggestions were dirty fuel filter, old fuel pump, electric pump at the tank.. So far I've changed the fuel filter, the mechanical fuel pump. I could not find an electric one and because it's a 22 footer it may not have one. I know is a fuel issue since i can spray starting fluid into the carb and get it running. I think my carburetor is next to get changed or rebuilt... any suggestions?
1986 Winnebago chieftain 22
454 with rochester carb
currently has 44K miles on it.
Jun-11-2012 12:14 PM
