k9-keno
Aug 11, 2023Explorer
Carrier to Dometic conversion
So I finally get my Dometic roof unit dialed in with my Carrier base inside. So I thought. Ac unit runs fine then maybe 3 days into our trip the unit shuts off Carrier board blinks 5 times. ( I think high voltage) is that code. Go outside pull power (yes on a surge protector)and disconnect batteries. Unit clears error from memory ran fine for a day or 2 did the same thing. My rear Carrier unit top and bottom it's all Carrier does not have any issues. I found only one post on the internet someone else was having this problem but nobody had a solution. Any thoughts on this? I checked my power coming in its fine. Am I just going to have to bite the bullet and buy a dometic bottom inside and thermostat?? I am I right saying the board is just not liking the Dometic at some points??? Thank for any input I know the Carrier AC issues since they went out of the RV business have been around. Thanks!!
