nbking's avatar
nbking
Caulking
I did a search on this subject and got 759 hits. Too much detail to go through for a simple question.
I would like to know what caulking to use in refreshing the original caulking on my motor home. Would we have to remove all the old caulking before applying the new.
  • For flat surfaces, use Dicor self-levelling caulk.
    For vertical surfaces, use regular Dicor.
    You can also use Eternabond in places where you are not concerned about appearance.
    For all of the above, follow the surface prep instructions.
  • As with google, you're not expected to read every single one.
  • Apply Dicor "Caulk" by caulking the places that need new "caulk". Unless the old "caulk" is badly deterioated, there is not need to remove before applying new "caulk". Eternabond tape is also a good alternative.
