CLASS A GEORGETOWN 280
BTWHITIS
POWER STEPS WILL NOT RETRACT. THE LIGHT IN THE STEP SWITCH DOES NOT BURN NOW.
3 REPLIES 3
enblethen
Should be two fuses in the battery control center. One should on the chassis for control from ignition switch and one from the battery operating the switch for motor power.
Since the light doesn't work, I am guessing no power or no ground under the step.
Bud
USAF Retired
Pace Arrow
2003 Chev Ice Road Tracker
cjd10
If fuse and magnets are good try tapping on the motor under the steps with a rubber hammer or block of wood. My 98 Georgetown used to do that once in a while and tapping on the motor would get them back working.
Although if light is not working either sounds like you may have lost power somewhere
Clyde and Elaine
2014 Georgetown 351DS by Forest River
2 Boston Terriers 1 French Bulldog
Rest in Peace Toby
Ramair
check the magnet on the door and make sure that it is lined up. Also check the fuse to the steps which is located under the steps themselves, to ensure you have power to them.
Andrew & Donna Reyes
2012 Georgetown 378 XL
