correct part number needed
MrWizard
Moderator
Moderator
For Ford 1996 F53 460"
With externally mounted tiff ICM
Finally got the right one ICM DY1077
Also installed new OEM motorcraft fuel pressure regulator
Pulled pcm relay and fuel pump relay cleaned terminals and swapped relays around
New distributor cap and rotor
Still having poor acceleration power problems
Fuel system checks ok, except Ned to have a pressure test done
Starts easy, idles smooth, obviously diagnostics give no engine problems or pcm problems
I can explain it to you.
1997 F53 Bounder 36s
6 REPLIES 6
MrWizard
Moderator
Moderator
i'm thinking of the distributor, because i sometimes get a PIP code error
but NOT every time
i also some times get a secondary fuel circuit error
Bruce_Brown
Moderator
Moderator
RLS7201 wrote:
As you well know from being on the forum for many years, the fuel pump on those old 460 F53 are prone to failure. I'm sure you also know the fuel pressure test needs to be done while driving at WOT. Should maintain about 32#. NO catalytic on 94-97 F53.
Richard
And they tend to work intermittently a lot too, until final failure.
Right when you think you've found the problem they act up again.
We fought the battle until we finally changed both fuel pumps, added a partial Banks kit, and took care of the converter.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
MrWizard
Moderator
Moderator
Fuel filter was the first thing I replaced
Resonator no Cat Converter
Corkey05
I'm just throwing this out as food for thought.
A stuck heat riser (stuck partially closed) ... I remember dealing with that years ago.
2008 HR Endeavor PDQ - Ford Edge 4 Down
FMCA F374292
RLS7201
Richard
95 Bounder 32H F53 460
2013 CRV Toad
2 Segways in Toad
First brake job
1941 Hudson
newman_fulltime
Partially clogged catalytic converter or exhaust in general what it sounds like to me. The engine either needs more air in or more air out if no codes showing . Every fuel pump I ever seen go bad once it gets hot it shuts off . poor power is also a sign of clogged fuel filter but hard starting is a sign for that
