Cruise Control
larrylu62
I just bought a 2004 Monaco Diplomat and found out the cruise control doesn't work. To test it, I let it idle and ran the engine up to about 1000 rpm. Then I switched on the cruise and it held the 1000 rpm as if it was working. Any ideas what to check next? Is there a fuse somewhere, or something else that may be simple? Any input would be greatly appreciated.
9 REPLIES 9
JackMS
Don't know if yours is setup this way or not, but a common problem on 18 wheelers is the parking brake switch. ECM needs to see park brake released for cruise to work and park brake set for high idle to work. Try setting high idle and release parking brake. If high idle kicks off, then this is not the problem. If high idle does not kick off this MAY be the problem.
Mr marks idea about jake switch is great too. Mine has exhaust brake but cruise will not work with exhaust brake switch on. I have changed every setting in ECM that looked like it might let cruise work with that switch on but no luck.
2005 Holiday Rambler Neptune 34pdd, Cummins ISB 300, Allison 2500MH, Onan 8.0QD
Prior Toad-2001 Chevy 2500 CC 4WD
Toad-2012 Honda CRV, Blue Ox Aventa II
Mr_Mark1
If you have a jake brake switch, the cruise will not engage if the switch is in the ON position. That's how ours works.
Good luck,
MM.
Mr.Mark
2021.5 Pleasure Way Plateau FL Class-B on the Sprinter Chassis
2018 Mini Cooper Hardtop Coupe, 2 dr., 6-speed manual
(SOLD) 2015 Prevost Liberty Coach, 45 ft, 500 hp Volvo
(SOLD) 2008 Monaco Dynasty, 42 ft, 425 hp Cummins
imgoin4it
If a brake light bulb is burned out the cruise control may not work.
Howard,Connie,& Bella,
One spoiled schnauzer
2007 Newmar KSDP
4dr Jeep Wrangler
crasster
Also remember that any brake light grounding will cause it to come off. Can you slip a small digital camera and a light under the hood to the cruise control to see if it is engaging (or at least a meter to test for 12V) at the cruise control box?
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
larrylu62
I tried it many times on the 200 mile drive home. If it was the brake pedal switch, surely the cruise would have worked on one of those attempts over a 200 mile drive. However, I will check the brake light switch tomorrow and then post again the results.
Thanks for the input guys.
dan-nickie
On my coach, that is how the High Idle is activated.
Dan and Nickie
2014 Forest River Berkshire 390RB
Johno02
Depends on where the speed pickup is connected. If it is sensing actual drive line speed, it will not work unless you are actually moving. Also, they usually will not work under 30 mph or so.
Noel and Betty Johnson (and Harry)
2005 GulfStream Ultra Supreme, 1 Old grouch, 1 wonderful wife, and two silly poodles.
the_bear_II
Some times the brake light switch at the brake pedal will cause a problem. If the switch isn't properly adjusted to contact the brake pedal shaft it can cancel the cruise control when you hit a bump in the road.
oldchief7155
Sounds like it's working. Have you tried it on the road yet?
