โJan-07-2014 07:44 PM
โJan-08-2014 07:17 PM
Ivylog wrote:
I'm sure Cat will let you bring it back if it will not fit although I THINK it will. Since you are in CO I'd park it on a steep hill with a full fuel tank... nose up. I'd prefill the filter and just change it quickly. If you needed to change it in SE Fla it would be hard to find a hill that gets the fuel in the tank as high as the filter. Another option is to put a valve in the fuel line at the engine so the fuel cannot suck air into the line. You still have to prefill the filter with clean fuel.
โJan-08-2014 07:13 PM
wolfe10 wrote:
There are adapters so that the Caterpillar manual primer pump can be installed at 45 or 90 degrees to the mounting plate. See what works best for you OR even better move the secondary filter to a more accessible location (as many manufacturers did when they built the coach).
The secondary filter (the one with the manual pump) needs to stay in the same position in terms of fuel flow (between lift pump and engine) but can physically be mounted anywhere.
โJan-08-2014 07:08 PM
cbeierl wrote:
I can't answer your question directly, put here's what I did on my 2005 Vectra, including pictures: Relocated Fuel Filter & Added Priming Pump
โJan-08-2014 05:10 PM
Ivylog wrote:
By "might be too extreme" I'll assume you mean fuel will come out of the base while the filter is off. Sounds good to me as you'll know no air has gotten in.
โJan-08-2014 12:25 PM
โJan-08-2014 08:37 AM
โJan-08-2014 07:41 AM
โJan-08-2014 05:43 AM
โJan-08-2014 05:20 AM
โJan-08-2014 05:19 AM
โJan-07-2014 08:11 PM
