Spizzer
Jan 09, 2014Explorer
Ivylog wrote:
I'm sure Cat will let you bring it back if it will not fit although I THINK it will. Since you are in CO I'd park it on a steep hill with a full fuel tank... nose up. I'd prefill the filter and just change it quickly. If you needed to change it in SE Fla it would be hard to find a hill that gets the fuel in the tank as high as the filter. Another option is to put a valve in the fuel line at the engine so the fuel cannot suck air into the line. You still have to prefill the filter with clean fuel.
Ivylog, yes, here in Colorado finding a hill is not a problem. In fact, my driveway is probably more than enough.
I'll make sure Cat will take it back if unused.
Thanks, jeff
38,707 PostsLatest Activity: Jan 05, 2014
