There are 2 1/2 FUSE boxes for the chassis systems
THE "Convinence Panel" under the dash has a a few circuits
The main chassis panel is likely under the hood. top dead center. You will see a plain black box NO legend. there are push to release clips on either side
THe box is a rectangle with a slight extenstion on the bottom
This is the MAIN fuse box
The half is optional and it is the battery control center. on my rig a 2nd black box to the right of the first. But it says "Battery control center" on the cover This is a mix of house and chassis systems. I seriously doubt that's your target though
Mine was in the MAIN box. (Top dead center)
