- wolfe10ExplorerMuch of the answer depends on your ability and tools.
Yes, I have done it with hand tools and bottle jack (larger engine-- Cummins ISL).
My suggestion is to crawl under there (with appropriate safety stands) and evaluate it for yourself. - FIRE_UPExplorer
newmar40jw wrote:
I have a Newmar Kountry Star 04' Cat desiel, how hard is it to change motor mounts? thanks
newmar,
Just wondering, hope this doesn't sound too dumb but, may I ask why you need them changed? Are they in poor condition? Oil soaked? Damaged? The reason I'm asking is, our coach is an '04 Itasca Horizon 36GD with the C-7 CAT and it's motor mounts seem to be in flawless condition and, I'm the one that does all the work on that coach/engine so, I'm pretty much aware of things like this. Again, just wondering.
Scott - NutHouse2016Explorer
wa8yxm wrote:
This is one of those jobs where I've seen Mechanics screw it up and take hours to do a 20 minute job.. Now to do it in 20 minutes takes a special tool. which was lying on the floor of the shop.. and the BRAINS TO USE IT. which sadly the mechanic did not have.
However I will support the professional help suggestion for they should have the tools... and you can damage things if you do it wrong.
Sounds from a brother trucker/mechanic/ham :) - wa8yxmExplorer IIIThis is one of those jobs where I've seen Mechanics screw it up and take hours to do a 20 minute job.. Now to do it in 20 minutes takes a special tool. which was lying on the floor of the shop.. and the BRAINS TO USE IT. which sadly the mechanic did not have.
However I will support the professional help suggestion for they should have the tools... and you can damage things if you do it wrong. - 2oldmanExplorer IIThat depends on how old you are.
- 1968mooneyExplorerStart a "Go fund me account" first. :S
- ArchHoaglandExplorerReally easy.
Take that baby into the Cat shop and tell them "Change the mounts." - Dennis12ExplorerPiece of cake. Take it to a mechanic.I always mess more up than i save
About Motorhome Group
38,712 PostsLatest Activity: Apr 06, 2025
