Sep-10-2020 09:09 AM
Sep-11-2020 10:14 AM
carringb wrote:dougrainer wrote:
California would be OFF the list. California is now cutting back electricity and asking for voluntary shut downs of electricity AND mandatory shut downs in certain areas. When I see these reports, WHAT about the People and Companies that rely on ELECTRIC vehicles in those areas in California????
California doesn't have an electricity shortage. They have a peak supply-demand imbalance. During they day, they can't use all the power they produce, and the peaking plants they rely on to balance the grid when solar and wind go offline can't ramp up fast enough.
EVs can help with load balancing by temporarily supplying the grid when the sun goes down, until the peaking plants catch up. But they also help by using more power during peak production, so that the slow-responding plants don't have to go offline.
https://thedriven.io/2019/09/20/nissan-inks-major-deal-with-french-utility-to-develop-vehicle-to-gri...
And let's not forget that many of the issue are due to simple inaction by PG&E. Lack of ROW maintenance, lack of power plant PMs, obsolete switchgear, failure to utilize smart-grid production agreements, failure to use predictive demand algorithms... I could go on. None of those issues would go away if everybody tomorrow traded their EV in for a gas-burner.
Lastly, EV owners are often a little better insulated against grid disruptions. Whenever planned blackouts are announced, there's a run on gas that often deplete the stations tanks. By the time they get refilled, the station doesn't have power to run the pumps anymore. EV owners can stay topped-off at home until up until the time power is turned off. And sometimes longer if they have their own array with off-grid support.
Sep-11-2020 08:07 AM
Sep-11-2020 06:21 AM
Sep-11-2020 03:17 AM
Bill.Satellite wrote:
I hope this is just a spammer testing the board as there is no possible conversion at this time.
Sep-10-2020 08:53 PM
Sep-10-2020 06:36 PM
Sep-10-2020 04:11 PM
Sep-10-2020 02:17 PM
Sep-10-2020 12:15 PM
Sep-10-2020 09:37 AM
carringb wrote:
There was a company that build a batch of EV E450s to use for Long Beach public transit. It works ok for stop-and-go use, but the physics of pushing a brick wall through the air don't lend well for EV use on the highway yet. For a viable EV motorhome, the efficiency of the chassis and aero need to be dramatically improved, and even then, a lot of batteries won't go far.
The Thor ACE is one of the worst designs for reducing drag because of the "forehead". The Thor Vegas and Axis are the best, actually allowing Thor to meet greenhouse gas limits for a Class 3 chassis.
You ace with it's Cd around 1.3 and frontal area estimated to be 86 sq. ft, would require 160 kW (including ~10% for driveline and accessory losses) to drive down a flat highway at 60 MPH.
The battery back from a Tesla Model X has a capacity 100 KW/hr. You'd only be able to drive your motorhome around 37 miles before needing a recharge. Assuming no headwind, hills, using heat etc.
For a usable range, you would need about 10 Model x battery packs. But each one weighs 1200 pounds. And your existing cooling system might not be large enough to reject the heat of 10 of those packs charging simultaneously. Using a 240v charger (to utilize campground power), you'd need 120 hours to recharge your battery bank to drive another 370 miles. Plus you'r need a 2nd pedestal to power the house while your chassis charges.
Sep-10-2020 09:34 AM
Sep-10-2020 09:33 AM
