โFeb-26-2016 01:55 PM
โMar-17-2016 07:37 PM
aintnothin wrote:
Update. Went over with my cousin and we started with the simple first. Had him go under and tap the the starter and boom, started right up. I'm happy, just a bummer I couldn't get under there myself.
โMar-17-2016 06:51 PM
45Ricochet wrote:
Have you put a meter on the starter solenoid?
โMar-17-2016 03:53 PM
โMar-17-2016 10:13 AM
โMar-17-2016 09:15 AM
aintnothin wrote:
Not yet but tomorrow the day! Sun will be out, temp above 60, cousin Committed! Frieght liner emailed me 4 really nice wiring nice wiring diagram to help me!
โMar-16-2016 04:20 PM
โMar-16-2016 03:27 PM
โMar-10-2016 03:47 PM
Bikeboy57 wrote:
Do you have a voltmeter? If not you are trying to solve an electrical problem by guessing. What are the voltage readings at the battery and at the starter when holding the ignition in the start position?
โMar-10-2016 03:41 PM
โMar-10-2016 09:27 AM
โMar-05-2016 08:18 AM
aintnothin wrote:teleman2 wrote:
Just replaced the starter on 2000 damon ultra sport. When turn the ignition switch sometimes it would start other times you would have to do it 2 or 3 times. Replaced the starter solved the problem. Oh it uses the battery's to start.
Glad to see someone with the same brand! I'm going to start with a couple of the easiest, the starter solenoid and the nuatral safety switch relay. If you could point me to those? I took the batteries in and had the tested a Napa and they are good.
โMar-05-2016 08:15 AM
โMar-02-2016 07:47 PM
โMar-02-2016 05:20 PM
