The touch pad control panel for my Equalizer hydraulic leveling system has gone bad. Everything was working fine, then one day the panel just refused to work. Did all the trouble shooting test, power to the board, checked the ground to the board, checked all the fuses, everything points to circuit board failure. Called Equalizer, they no longer have the 2086 panel, but they do have an updated - retro panel. By the time I purchase the panel, and have them install all necessary hardware updates requires the repair will run between 3 and 4 thousand dollars.
With that being said, I'm searching for a used or new old stock 2086 panel. I've tried several MH junk yards and surplus dealers with no luck. If anyone has any suggestions where to look next, I'm all ears.
Thanks in advance.
