โFeb-27-2016 06:20 AM
โMar-25-2016 04:40 PM
gonesouth wrote:You would be right in that regard. Buying a new vehicle in Europe is very costly due to the added taxes and duties attached to NEW vehicles. However, there may be an advantage to buying in the US and then converting to Euro standards as the rig would be imported as a USED vehicle, where the taxes and duties are less.
I've camped with two different families that bought rigs in the US and then imported them to Europe. Saved huge amounts of money, so I would think that importing from Europe would be financially prohibitive.
โMar-25-2016 02:42 PM
โFeb-29-2016 01:41 PM
tarnold wrote:A lot of money, time and effort. First problem will the roof AC will be 220 VAC. Replacement is going to cost maybe a bit north of $500. Microwave won't work, TV will be totally non-functional (different scan standard besides power). Electric water heat is out same for the fridge but swapping out the heating element should solve the problem presuming the new elements will fit. Also you'll need to replace the AC to DC convertor. All the outlets will have to changed out. Or you just find a 3600 watt for 30 amp or two 6000 watt step up transformers and never plug any locally acquired appliances or devices that can't take 220 VAC in to any of the outlets. All that is if the coach is equipped with what we normally see here in North America. I found a web site once of a modifier in the UK that will convert our rigs to their standards. The list of stuff to change was pretty long.
OP here. Guess what I was getting at was what would it take to get one of "their" rv's to work over here?
โFeb-29-2016 09:46 AM
Kayteg1 wrote:
Why is 220V called single phase when it has two phases?
That would be the same dilemma why 240V is called 220
European RV are not as big as US models and I don't think too many of them have microwaves or electric coffee makers or AC.
3 amp at 230V will support almost 700W, so it adequate for most.
โFeb-29-2016 09:03 AM
โFeb-29-2016 08:32 AM
MrWizard wrote:
in the USA the 'Nomenclature' is single Phase, and three Phase
there is NO 'two phase'
phasing is not the same as voltage difference
USA 240v/120v is single phase same wave form, the voltage is off a center tap at the transformer and there is ONLY ONE secondary winding/output, it is 240v across the winding, the neutral is the center tap it is ONE wave form always the same phase
i won't get into Eurpoean electric service
โFeb-28-2016 04:48 PM
โFeb-28-2016 04:09 PM
Kayteg1 wrote:DrewE wrote:
Probably the easiest would be to wire up a 50A plug converter. So long as the campground has a proper split-phase 50A socket, there is 240V between the two hot legs. The neutral line in this case would not be used. This adapter would not work with a 30A connection, even with a 30A to 50A adapter.
It might be possible, though I would not think it likely, that you may find some campgrounds where the two legs are actually two of the three phases of a 120/208 three phase supply, in which case the voltage between the legs would be 208V.
Not that easy.
US 120V comes from 2-phase 240V, while European 230V comes from 3-phase 380V.
In other words - US 240v is between hot and hot wire, while EU 230v is between hot and ground.
My limited knowledge about electricity would make me guess that resistors don't care about the phases, but anything else might.
โFeb-28-2016 03:29 PM
โFeb-28-2016 11:24 AM
45 Richochet wrote:
In some areas I guess but not all .Didn't see one slide out.
โFeb-28-2016 07:56 AM
โFeb-27-2016 06:43 PM
โFeb-27-2016 06:39 PM
โFeb-27-2016 06:36 PM
