Dec-16-2013 01:04 PM
Dec-20-2013 09:19 AM
Dec-20-2013 03:45 AM
stuplich wrote:
I can't understand why anyone would use a lube other than one recommended for a particular job.
Mel
'96 Safari
Dec-20-2013 03:32 AM
2ndhom wrote:
I have a 2006 Cat 400 HP ... where would I find the location that should be lubed?
Dec-19-2013 08:18 PM
Dec-19-2013 08:40 AM
deandec wrote:
"But, one can certainly choose to ignore factory recommendations-- true on just about anything."
Since the Pac Brake branded oil is just Super Lube Synthetic oil, blind obediance, buying the specified oil from Pac Brake, is the result of a good marketing marketing plan.
Even the link on the Pac Brake web site connects to the material safety data sheet at Super Lube. The flash point is 428 degrees according to the manufacturer.
Dec-19-2013 08:18 AM
Dec-18-2013 12:45 PM
cbeierl wrote:
I can't speak to the WD-40 you're referring to, but here's what I use: Pacbrake Superlube Exhaust Brake Lubricant
Dec-17-2013 12:26 PM
deandec wrote:
I have two types of WD 40 on my shelf.
The Original and their "Specialist" Water Resistant Lubricant.
They claim it is good to 500 degrees.
So perhaps it would be as good as the Superlube that I have used for the past 11 years?
Dec-17-2013 10:18 AM
Dec-17-2013 10:06 AM
Executive wrote:
Use the proper lube..WD40 isn't a lubricant, it's a water displacement. Get it from PacBrake....Dennis
Dec-16-2013 08:35 PM
Dec-16-2013 06:25 PM
Dec-16-2013 04:35 PM
Dec-16-2013 04:08 PM
