โMay-01-2017 06:32 AM
โJul-03-2017 01:00 PM
โJun-30-2017 03:49 PM
โJun-30-2017 03:11 PM
mrmomb wrote:
I replaced front and rear sway bars with Hellwigs. The rear came with new end links however the front uses Ford's stock mushy end links. Are there any aftermarket stiffer end links available that are recommended?
โJun-29-2017 06:08 AM
j-d wrote:I "Totally Agree" with you. 100% !!!
A wheelbase that's long enough to have a good WB-to-Length ratio, is also going to cause a good front axle loading.
This is my "wheelbase conspiracy theory:" In coaches bigger than about 24-feet, the manufacturer wants to hang a walkaround queen bedroom like the 31-footers have. They don't want wheel wells in the bedroom, so that bedroom starts AFT OF THE AXLE, regardless of the overall coach length. A 31-foot can handle that because the rest of 31-feet goes between the axles. That weight provides good loading on the front axle. It also relieves some of the load on the rear axle. I realize that's another way of saying the same thing. But I'll tell you this: Look at a coach, particularly a Class C, where it seems the House part (not counting the cab-over) is "balanced" (meaning centered) on the rear axle, looking from the side. You're looking at one that's going to have handling problems, an overly light front axle, and possibly an overloaded rear axle.
OH, if the coach is rear-end-heavy, all the more reason for an upgraded rear sway bar.
โJun-28-2017 05:22 PM
โJun-28-2017 03:47 PM
ron.dittmer wrote:
I think people driving shorter rigs with large rear overhangs notice a bigger improvement with HD bars due to the poor ratio of "wheel base to length" but all rigs benefit.
โJun-27-2017 03:33 PM
j-d wrote:IAMICHABOD wrote:
Yes the newer 4500 chassis comes with a Rear Stabilizing Bar
From what I can tell from the video, that rear sway bar looks like a worthwhile one. My guess is at least 1-1/4 inch maybe bigger, a lot more than Ford installs. The Hellwig rear bars for Class C are 1-1/2, and the Chevy bar could be that or close.
โJun-27-2017 03:25 PM
โJun-27-2017 11:15 AM
โJun-27-2017 09:28 AM
Newbiecampers wrote:
Does anybody know if a Chevy 4500 chassis would benefit from a hellwig-type (or any other company) sway bar upgrade?
I did a quick search here and could not come up with anything. I also searched online and did not find any hellwig product for a chevy 4500 after the 2009 model year, unless my search-foo failed.
Do the chevy 4500 chassis come with better swaybars from the factory?
We may be getting a class C on a chevy 4500 chassis that is a 2012 or 2013 model year.
Thanks
โJun-27-2017 08:51 AM
โJun-27-2017 08:23 AM
blownstang01 wrote:
...I just drove through a pretty major thunderstorm on our way to Nashville last week (no real easy place to pull over), between these sway bars and a proper alignment with 6+ degrees caster the difference in handling in the wind is truly huge. At least for me, worth every penny...
โJun-27-2017 08:17 AM
โJun-27-2017 07:36 AM
โJun-25-2017 01:39 PM
