ddro's avatar
ddro
Ford e450 tire pressure check and fill problems
We just bought our new Itasca Spirit 33 foot long motorhome and I am having one hell of a problem checking and filling the tire pressures. The inner wheels have braided stainless steel extenders I assume that go through a wire connector that mounts on the outer wheel and I have a heck of a problem trying to check and fill them as the valve stem (or extender) is flexible and I have to hold pressure on them to get the gauge and chuck on them. I really have to push the gauge and chuck hard onto the stem to get any reading and to fill. Also the damn outer stems face inward, how the heck are you supposed to get a gauge or chuck on them?
On our first trip I got a screw in the inner tire and a flat. Luckily I noticed the outer tire looked low and after checking found the inner flat. I was able to get about 35 PSI into it and drove a mile down the road and had the flat repaired. (lucky)
When we got home I decided I wanted to check the pressures all around again and the wheel covers make it almost impossible to check when they are installed and I have no idea as how to get a chuck or gauge on the outer tires with the stems facing inward.
Anybody else having trouble or have any ideas?
