2005 Georgie boy pursuit. Does the fresh water tank need some bit of water for the pump to work. Right now there is no water in the tank at all I flip switch on panel for water pump nothing happe...
My guess is the pump is running but you can't hear it because it's not pumping anything. My pump is nearly impossible to hear when I run out of water. Find the pump and put your hand on it. You should be able to feel it running. Be carful not to let it run dry for very long. I have never heard of a "float switch in the freshwater tank.
