Genset (2016 Tiffin RED PA37) won't start.
Squealers
Just picked up a new to us Tiffin yesterday. Check out went well. Genset fired up with ease. Drove 7 hours today. Pull into WM. Go to start genset and nothing but light rapid clicks like the battery is dead. Does anyone know if it's a dead battery? I'm assuming it has a separate battery. But not sure.
Coach only has 4K miles and is 7 months old.
Have half a tank of gas.
Any ideas would be great.
Thanks Keith.
2006 Four Winds Hurricane 34N
2014 Jeep Cherokee 4X4 Toad
USAF Veteran. 75-81 SAC "Giant Talk" ATC-
Combat Crew Communications
Squealers = Steelers & Arkansas Razorbacks Fan
16 REPLIES 16
newman_fulltime
Sounds more like a loose batt cable
DrewE
Most commonly (but not universally) the generator starts from the house battery. Occasionally it's set up to start from the chassis battery. In either case, if the battery is too low you usually can start it by first starting the main engine so the alternator supplies some of the starting power.
It is a very rare setup for an RV generator to have a dedicated starting battery.
