Headlights and covers
Iwannago
I lost a headlight lens cover from a 2004 HR Admiral. Does anyone know if and where I can just get the cover? Or what car or truck the headlights are from ??
Thanks, I found replacement headlights on EBay for 135. If I go that route are they hard to replace?
Thanks again,
Jim
Jim @ Sharon Alonzo :C
3 REPLIES 3
jlmowery
My 95 Damon Ultra Sport, built on a Ford chassis, uses the same headlights as my 98 Ford F250 pickup. Look to the chassis builder and you should find the headlights/covers. For a less expensive route, consult your local auto recycling yard.
jwmII
Auto parts stores sell this stuff. Take your numbers off the other lense, keep in mind it is the opposite hand from the part you really need. The number will reflect that. Access the back side of the light that actually needs the part. There are usually numbers there that will identify the entire unit. You may fair better by replacing the whole thing. NAPA is one place for sure that you can get the part.
jwmII
CG_Dawson
"google" the numbers found on the other lens, you should find the info you are looking for.
Happy RV'ing!!
Greg & Jackie
2003 Bounder, 32W / Ford V10 / 2 Slides
Toad: 2004 Saturn L300, Brake Buddy
