scarpi
Jul 03, 2013Explorer
heat causing problems inside RV
Hi all, our Phoenix summer temperatures are causing problems with the bathroom walls in our PW Excel. It is an 09, and the temperature inside the RV sometimes is 115 even with the fantastic fan vent open and the bathroom door left open. The RV sits in our driveway at home when not in use. Of course our summer temps here are HOT (100 - 115 daily)! So the inside of the RV cooks. The problem is that the caulking in the bathroom is separating, leaving gaps between the walls. The same thing is occurring on the bathroom counter top where it meets the wall. Also for those of you familiar with the PW Excel, there is a wall panel attached to the bathroom wall above the window that looks like a formica type panel. The edges are becoming completely separated from its backing due to the heat warping it. Here's my questions. First of all, is there a better caulking that I can use to recaulk the seams between the bathroom walls, and secondly is there a good adhesive that could be used to reattach the formica type panel where it is warping off the wall? Since it is the edges that are warping, I can't get behind the whole panel and would need to drip some adhesive into the gap and tape it shut until it cures. Thanks for any info......Don in Phoenix.
