Holiday Rambler or Fleetwood
mike_brez
Both are 2007 and almost same price.
HR Ambassador SKT,RR8R chassis,Cummins 330 isc,glass roof,steel cage cockpit(I like that)
Fleetwood Revolution Le Spartan chassis,400 C9 Cat,1-1/2 bath,glass roof.
Thoughts? We like all in one baths no walk throughs.
1998 36 foot Country Coach Magna #5499 Single slide
Gillig chassis with a series 40
02 Ford F250 7.3 with a few mods
2015 Wrangler JKU
19 REPLIES 19
eheading
Well, I've had a Monaco diesel and a 2005 Revolution LE. In my humble biased opinion, I would take the Revolution hands down. Although it may have laminated walls, if you look into the details of the construction and the way things are assembled and connected, you'll soon see that the Revolution LE is the better of the two. In addition I like the side radiator of the Revolution vs. the rear radiator.
There is always this back and forth about the Roadmaster chassis vs. a Spartan chassis. They definitely ride and handle differently. Drive one and see which YOU prefer. My preference is for the Spartan. I found the Roadmaster to be a little harsh for my taste. In addition it has considerably more unsprung weight which tends to add to its harshness. As a side note, it is interesting that the new 2015 Dynasty is being built on the "new Roadmaster chassis" which is identical to the Fleetwood Liberty chassis.
I would not worry about the engine choice. I always said I would not choose the coach by the color of the engine. I had had 3 Cummins engines before the CAT in the Revolution. Personally I couldn't see much difference. The C9 is a very good engine. We drove ours over 95,000 miles before trading it on a new coach this spring and it did VERY well for us.
As others have said, drive one, think about living in one, and pick the one that fits you best!
Good luck!
Ed
topflite51
All things being equal RE: floorplan, color, etc GO FOR THE HORSES.
:CDavid
Just rolling along enjoying life
w/F53 Southwind towing a 87 Samurai or 01 Grand Vitara looking to fish
Simply Despicable ๐Ÿ˜›
Any errors are a result of CRS.:s
krivanj
The Rev LE is a much higher level coach chassis than a regular Rev. The LE was built on a Spartan Liberty chassis, much stronger than a regular Spartan or Frieghtliner.
Do research on the LE chassis before you buy. You will be pleased.
Original factory brochures are available online at Fleetwood or American.
Fleetwood Revolution LE 38X
2011 Scion TC toad
nbargolf
We have a Fleetwood and love it. All the other options here are just like mine options, we all love the coach we have so I won't try and tell you this one is better than that one. I don't think anyone can unless they have own both of the coaches in question. We can tell you ours is a good stable ride. Good luck go with what you are comfortable with.
JimM68
In that year range, ambassador (and my knight) were "mid-range" coaches.
They were identical to Endeavor / Diplomat except for the engine (360hp isc vs 400 hp isl.) All were rear radiator.
I cannot say enough good things about the 8 bag roadmaster chassis.
Jim M.
2008 Monaco Knight 40skq, moho #2
The "68"
My very own new forumfirstgens.com
My new blog
mike_brez
Valkyriebush wrote:
The American Rev is a higher end rig than the HR Amb? I'd go with the Rev.
I thought that also...but is it really
2015 Wrangler JKU
Valkyriebush
Command Master Chief (AW) USN, (ret)
2003 Fleetwood Excursion 330 Turbo Cat 39D
2000 Jeep GC
2005 Big Ruckus (Rides Behind Jeep)
2003 VTX 1800
Bruce_Brown
Moderator
Moderator
I'm a big fan of the HR construction vs the Fleetwoods (hung wall vs laminate) and 99 times out of 100 I'd the HR. This case might be the 1 time I'd say Fleetwood. The engine difference alone would make me look hard at the Fleetwood.
Having said that, look close. The Fleetwood is laminate construction, and things that are laminated tend to delaminate over time. That simply can't happen with the HR. The other thing is take a good look at how things are screwed together. That MY was juust before the big crash and some companies were feeling the pressure. Being '07's you should be good with both, but take a look.
2 good choices, but if all else was equal I could hear 400 HP calling my name.
There are 24 hours in every day - it all depends on how you choose to use them.
Bruce & Jill Brown
2008 Kountry Star Pusher 3910
mike_brez
Mr.Mark wrote:
If it were me, I would go with the one with best floor plan that works for you. The bath and a half is a plus. It might be that the HR doesn't have the Particulate Filter which started on some 2007 models (DEF came out in 2010 coaches). The extra HP in the Fleetwood does sound enticing.
Our 2008 has the Particulate Filter and we've had zero problems with it in 7 yrs. and 65,000 miles. Our new coach will have DEF.... I like clean air.
MM.
We like both floor plans. I think we are kinda leaning towards the Revolution.
2015 Wrangler JKU
Mr_Mark1
MM.
Mr.Mark
2021.5 Pleasure Way Plateau FL Class-B on the Sprinter Chassis
2018 Mini Cooper Hardtop Coupe, 2 dr., 6-speed manual
(SOLD) 2015 Prevost Liberty Coach, 45 ft, 500 hp Volvo
(SOLD) 2008 Monaco Dynasty, 42 ft, 425 hp Cummins
B_s_Bunch
Never owned a HR although have seen many very nice ones. Even in older age still look very impressive. We have owned two Spartan Chassis and have not had any trouble with either. One with independent front suspension and one without and I seriously can not tell the difference driving but loss of wheel cut is noticed in some instances. I have made choices when Spartan was not available but that is just the way I think. Drive both and decide. Larry
Larry,Brenda,Travis,Jarred & MEME the Boston Terror:E TheBunch 2011 American Coach Revolution 42T:C The Double Wide
krivanj
The Spartan LE chassis was one of the strongest ever made. If you look up NADA original and now, I think the Revolution is higher in both cases. Having said that, we were all set to buy an Ambassador until we saw our Revolution. It is ALL about condition.
By the way, we love our Revolution, so we are biased...
2011 Scion TC toad
The_Texan
Spartan is better than a "Freightshaker" but the 8 bag Roadmaster is the better of these 2.
Bob & Betsy - USN Aviation Ret'd '78 & LEO Ret'd '03 & "Oath Keeper Forever"
2005 HR Endeavor 40PRQ, '11 Silverado LT, Ex Cab 6.2L NHT 4x4, w/2017 Rzr 4-900 riding in 16+' enclosed trailer in back.
Where the wheels are stopped today
Sully2
Im a Fleetwood man thru and thru and I always prefer larger engines...but with your specs....Id go the HR with the 330 hp Cummins
presently.....Coachless!...
2002 Jeep Liberty
2016 Ford Escape
