mobileempire
Sep 09, 2013Explorer
Honda 2000i from van fuel tank?
I have easy access to my fuel pump and its easy to remove , so since the top of the fuel pump is made of plastic I plan to drill a hole thru the plastic fuel pump while the pump is removed from the van , i plan to use this hole as my fuel line pickup , connections at the generator end seem simple enough, so the only problem I see is venting , how would I go about venting the vans fuel tank?
Its a 1996 Chevrolet Express van and I believe these vehicles trip a code when the gas cap is not tight , so I was thinking that if I vented the vans tank mayby it would trip a code.
Any thoughts , suggestions, advice?
