Hot water not lasting
bhivetravels
Last few days our hot water is not making it through two showers (10 gal). It used to easily handle the two showers ... If I switch on the propane it will make it, just not while on electric alone. Is there anything I can do maintenance wise to fix this?
Jim and Monica
Maj. USAF Ret. โ€” High School Teacher Ret.
2016 Jayco Pinnacle Ford 350 Turbo Diesel
Full-Timing with Meiko and Marlie:C
21 REPLIES 21
bhivetravels
OP I will fill the fresh water tank and let you know how that goes ... interesting. And yes I've had the hot water tank serviced annually but it is 7 years old.
Jim and Monica
dahkota
Definitely the cold water temperature. It is in the 30s and 40s here and the difference in the length of hot showers is noticeable from last month in the 60s and 70s. And our rig is new - no time yet for build up...
2015 Jeep Willys Wrangler
2014 Fleetwood Bounder 33C
States camped: all but Hawaii
more than 1700 days on the road
nomad297
MrWizard wrote:
put fuel in the RV and drive to a warmer climate :B
NO. its not maint issue..its the cold water comming in from city inlet
fill your fresh tank, turn off the city inlet connection
once the fresh water tank warms up..(24hrs) the showers will last longer
as you will be mixing less hot water
also i would switch to LP
its cold you are going to need it
i would rather pay for LP and have hot showers, than worry about running out of hot water
This is the problem.
I am a plumber and every year as the service water gets colder and colder, we get more and more calls from people thinking their water heater is going bad. I could take advantage of this and sell a load of water heaters every fall and winter, but I am an honest plumber.
Bruce
2010 Skyline Nomad 297 Bunk House, 33-1/4 feet long
2015 Silverado 3500HD LTZ 4x4, 6.0 liter long bed with 4.10 rear, 3885# payload
Reese Straight-Line 1200# WD with built-in sway control
DirecTV -- SWM Slimline dish on tripod, DVR and two H25 receivers
TucsonJim
X2 on OldBiscuit's comments above. May very well be maintentance issues.
2016 Ford F350 Turbo Diesel SRW 4x4
2017 Grand Design Reflection 297RSTS
2013 Ford F350 Turbo Diesel SRW 4x4 (Destroyed by fire - 8/29/16)
2014 Grand Design Reflection 337RLS (Destroyed by fire - 8/29/16)
Old-Biscuit
This is in your 07 Coachman?
7 plus yrs old water heater......so have you been routinely clean/flushing tank?
Mineral build up inside tank and on electric heat element will reduce heat transfer capabilities.
Also......is water actually heating to full t-stat set point?
T-stat ever been changed?
Is it tight against tank wall....making contact with a clean surface?
Which Brand/Model Of water heater?
Does it provide adequate hot water on just propane?
With combo (electric & gas) both can be used at same time for faster recovery time>>>>>>not a cure just a work around until you check out element, t-stat and actual temp of water (at PRV----------CAUTION water should be hot like 130*F-140*F)
camper19709
x2. What MrWizard says about the very cold water coming in. Warm it up a little in the fresh tank first ๐Ÿ™‚
Chip
06 SurfSide
30ft class A
2 slides
Ford V10 chassis
04 Chevy Astro van toad
MrWizard
Moderator
Moderator
I can explain it to you.
1997 F53 Bounder 36s
