Hot water odor only, cold is ok
Stepheng1
Son borrowed class c motor home, called and said odor coming from hot water only, cold is OK. Any ideas?
Stepheng1
16 REPLIES 16
ronfisherman
Moderator
Moderator
TomBird wrote:
Camco 11691 Water Heater Tank Rinser
by Camco
2004 Gulf Stream Endura 6340 D/A SOLD
2012 Chevy Captiva Toad SOLD
TomBird
by Camco
bukhrn wrote:
My bad, sorry Bob I simply didn't scroll down far enough. :S
:B
But I guess I could have linked the exact one too!.....
2007 GMC 3500 dually ext. cab 4X4 LBZ Dmax/Allison - 2007 Pacific Coachworks Tango 306RLSS
RV Rebuild Website - Site launched Aug 22, 2021 - www.rv-rebuild.com
bukhrn
2007 Forester 2941DS
2014 Ford Focus
Zamboni, Long Haired Mini Dachshund
bukhrn
BobsYourUncle wrote:
Try This
Couple options here
Umm, I don't think so, that's a Black Tank rinsing tool, the one j-d posted is the correct one, you can also get it at Camping World, or almost any RV dealer, it simply called an, RV Water Heater Tank Rinser
2014 Ford Focus
GordonThree
If your rod is in good shape but just stinks, wrap it in foil and put it on the grill next time you cook something. The heat will sterilize it (it's metal loving bacteria making the stink). Give it a brushing and put it back in service. Like others suggest, flush the tank while you have the anode out.
Did this myself a month ago, worked great.
Try This
Couple options here
Stepheng1
J-D
What tool am I looking for on Amazon? can you give me a name to search.
j-d
Inspect/change Anode (again if Suburban, Atwood doesn't use Anode) and either way you can rinse with the home made wand or get this one. This pic is a $7 one from Amazon
Stepheng1
Great thanks everyone
Mine starts to stink too after a lot of use.
There is a buildup of a jelly like schmoo inside the tank. This is normal and does happen.
The tanks do require periodic cleaning.
I fabricated a long nozzle from a piece of about 3/8" copper pipe, soldered an end onto it to thread onto a garden hose and I bent the end of the pipe on about a 60 degree curve and flattened the end to form a narrow nozzle.
I take the anode rod out once in a while and stick this homemade device in the hole and turn the water on. The curve on the end shoots out a high pressure stream and cleans the goo off the inside of the tank. It flows out the hole onto the ground. I run it until no more stuff comes out.
Then the smell goes away.
tpi
Stepheng1
Being borrowed, it may have sat for a long time..with water from some sources leading to the smell. With use, and water from different source the smell may go away on it's own.
3oaks
ronfisherman wrote:
Need new anode rod in Water Heater if it is a Suburban.
And flush out the tank after removing the old rod before installing the new anode rode.
ronfisherman
Moderator
Moderator
