House battery charging problem...
goufgators
This in re: to a 2017 Winnebago. The coach had sat for a few weeks and when I went out to move it today, the coach batteries were dead. It has been constantly plugged into a 30A receptacle. In addition, I had left the on/off 'salesman's switch' in the on position. Isn't the inverter or is it converter supposed to keep the batteries topped off when a/c power is provided thereby preventing discharge? Or, should I have left the on/off switch in the off position? Thanks for any advice. BTW, it's under new veh. warranty but thought if something simple or that I'm doing something wrong, advice from you knowledgeable members might save me from a 60 mile round trip to CW.
2017 Winnebago Sunstar (gas)
2005 Honda CRV Toad
Invisi-brake
16 REPLIES 16
goufgators
Acampingwewillgo wrote:
I can't speak for the newer RV's but I know the older models, the inverter /charger did not charge the chassis battery, only the house. They use to sell a product that connected between the chassis and house batteries in order to keep the chassis batteries topped off. (I believe it was called an Echo Charger).
The chassis battery is fine. Problem only with coach batteries.
2005 Honda CRV Toad
Invisi-brake
Acampingwewillg
96 Vogue Prima Vista
The Kid's: Humphrie, the Mini Schnauzer and Georgie,wire haired dachshund.
Rainbow Bridge: Laddie,Scoutie,Katie,Cooper,Kodie,Rubie,Maggie, Cassie, Mollie, Elvis, Potter and Rosie Love You! (40+ years in all)
