โAug-15-2004 01:22 AM
โJun-19-2016 08:21 PM
new v'er wrote:
Still will camp but not sure what the road holds up ahead as we are retiring in 2017.
โJun-19-2016 09:39 AM
โJun-06-2016 08:20 AM
PoorGary wrote:Griff in Fairbanks wrote:
In one word, yes ... to both questions.
Don't let the hub extender throw you. It's actually easier than many newer vehicles, like the 2004 Silverado 2500HD.
The picture is great! It looks like a fairly standard Kelsey-Hayes dual piston set-up. The two bolts on the caliper, visible in the picture, disconnect the caliper from mounting bracket behind the rotor. Take those out and the caliper lift off the rotors with no more difficulty than usual. (The calipers weigh quite a bit more than light truck calipers.)
I'd recommend changing the brake flex lines while you're at it. At about $10 each, it's a cheap improvement in reliability.
Is your brake booster mounted on the master cylinder? Or, do you have single or double frame-mounted brake booster(s), with slave cylinders? If frame-mounted, the bleed procedure will involve additional steps than you're probably used to.
BTW - you have the readily-available "high-hat" rotors, which is good. My '73 RM350 had the f'ing hard-to-find low hat rotors, which took almost two years to find replacements. (Amazingly, I found the replacements on Amazon, of all places.)
Thanks Griff. I guess the hub extender threw me off. I found the right caliper bought the smaller brake hose and got it all on bled the line no problems. Caliper was in stock readily available.
Sadly it still wont move likely due to the back brakes seizing after sitting 7 months in the west coast rain. The torque of the engine would not loosin anything.
Was really hoping for a better day.
It sits low and in a bad place to jack up the rear end.
Maybe on the weekend I'll try tugging it forward with my truck.
Any other suggestions would be awesome to free them up
without removing the wheels.
Take care
โApr-19-2016 10:00 PM
Any other suggestions would be awesome to free them up without removing the wheels.
Take care
โApr-19-2016 09:04 PM
โApr-11-2016 12:35 PM
โApr-11-2016 08:23 AM
โApr-06-2016 07:06 PM
โApr-06-2016 05:33 PM
PoorGary wrote:
Ok thanks. The next size up will cost me 599.00. Wont spend that. How about for lifting up the front wheels then putting in the jackstands. If the stands are in place then if the 3 ton jack failed it would stay up on the stands.
I know you guys dont recommend it but in a pinch it would work?
And what about a bottle jack..rather than a floor jack? Whats best?
It seems to me back in the day everything was jacked up off the front bumper.
โApr-06-2016 04:16 PM
โApr-06-2016 02:45 PM
โApr-06-2016 02:36 PM
Leeann wrote:
I'd be a little leery of 3 ton for a 24'. Go for 6 ton and you'll be okay.
โApr-06-2016 01:52 PM
โApr-06-2016 01:46 PM
โMar-10-2016 04:44 AM
Griff in Fairbanks wrote:Ballenxj wrote:
Let's forget the motorhomes for a moment. Griff, how are you doing?
Reasonably good, engaged in a steadily increasing level of cardiac rehab.
The primary cause of this heart attack, as well as the previous one almost two decades ago, was mental and emotional stress, with age to a lesser extent. Been taking it easy and avoiding things that cause me stress as much as possible. Moderate exercise is both a stress reliever and a means to improve cardiac function.
Thanks for asking. I probably should have commented sooner but I've been focused on rehab.
