โApr-03-2016 09:00 PM
โApr-12-2016 11:29 PM
โApr-12-2016 11:01 PM
โApr-12-2016 04:43 AM
backhoemike wrote:
Thanks for the help I haven't figured it out yet as they hid it behind the rear bumper HWH Model # ap1079 SN: 6295 on a 40' Newmar London aire
โApr-11-2016 09:15 PM
โApr-04-2016 08:07 AM
dougrainer wrote:
There is no sensor for overfilling. Odds are, either the solenoid that controls power to the Pump motor is bad or the motor is bad. At the pump, you will see either 1 or 2 solenoids. One solenoid will have a heavy gauge wire that goes to the pump motor. Jump the 2 LARGE posts on that solenoid. That will apply power directly to the Motor. If it does NOT run and you are positive you have good 12 volt power to that solenoid the motor is bad. IF the motor runs, then either the solenoid is bad or the activation wire to that solenoid is not functioning. Doug
Really need year model of RV and model of HWH system.
โApr-04-2016 04:44 AM
โApr-04-2016 03:50 AM
