I-65 Nashville to Indy
MRUSA
I would like to get a road report from anyone who has travelled this route recently. I have been told that it is a very rough ride. Also heard of construction delays. Is this true of the whole route, or can someone pin-point the problem areas so I can plan a detour?
Marc, Wellington FL
2013 Entegra Anthem 44SL
2018 Lincoln MKX toad
EEZ-RV tire pressure monitor
12 REPLIES 12
rvten
When we head home from the Escapade in Goshen.
I plan to take I75 home. Just to avoid Indy and I65.
Tom & Bonnie
Crossville, TN.
Aspect 29H 2008 Type C
Ford Flex SEL 2010
There is NO B+
Whaler
You can avoid IN 65 by taking I24 and getting off on the parkway to Hopkinsville KY (forget name) and on to Evansville where you will pick up the new I69. The new portion ends at hyw 231 and it is two lanes to Bloomington and four lane hyw 37 to Indy. Much less traffic but 37 has some stop lights to deal with. New 69 should open to 37 in late 15.
MRUSA
Thanks. I'm heading for Ft. Wayne, so I-71 to Cincy is not too big a detour.
Marc, Wellington FL
SPRING_STREET
MRUSA wrote:
How about I-71 from Louisville to Cincinnatti as an alternate?
Don't know what your final destination is, but the road going from Louisville to Cincy is very good on I-71....
2011 MOUNTAIN AIRE 4344, FMCA F334596, Cummins Power Play,Good Sams and KOA member..TOAD 2017 Ford Edge Titanium with a 6 cylinder Engine, License plate "TOWED" > RoadMaster Night Hawk Tow Bar and Base Plates. ๐Ÿ˜‰
luvlabs
After coming up I-65 and US 31 to Elkhart this week, I would suggest you not drive in Indiana. This state has, by far, the worst roads of any state we have been in. There was a news segment the other night about how Purdue University was researching how to make Indiana roads better - most states figured this out years ago so that should give you some idea.
I-65 from Scottsboro north to Indy to Franklin can be tough. There is road and bridge construction in this area and some single lane. Other than being rough and full of pot holes and poor bridge transitions, traffic wise wasn't too bad.
I-465 - East from the junction of I-65. Under construction and quite rough in areas.
I-69 - pretty good
US 31 - no traffic but some road construction in Carmel. Condition of road depends on county you are in. Best section is around Kokomo.
2017 Winnebago Navion 24V
2014 Tiffin Phaeton 36GH (sold)
2012 Tiffin Allegro 32CA (traded)
2012 Honda Fit
MRUSA
Marc, Wellington FL
rvten
I-65 is as rough as a corn cobb.
Even what they repaired is rough.
Heading up to Goshen, IN. for Escapade.
Tom & Bonnie
Crossville, TN.
Ford Flex SEL 2010
There is NO B+
BurbMan
Was up that way this week. Construction at Scottsburg has traffic to one lane then crossing over to the SB side...very slow going with the trucks meandering through the construction zone.
I am up to Chicago every week on 65, best time to travel if you can is the evening, fewer trucks and way fewer idiots.
Left Chicago 5pm CST yesterday, saw quite a few RV transporters running at night.
Peg_Leg
Just came up through there Tuesday. Construction at the 42 MM in IN had traffic to a standstill. I got off at the 36 MM and took US-31 north. Had to wait several light cycles at Hwy 50 for left turns back to I-65.
I use a cell phone app WAZE it gave me the info about the backup which I visually verified from 31.
2012 Chevy 3500HD Dually 4X4
Crew Cab long bed 6.0 gasser 4.10
2019 Open Range OF337RLS
Yamaha EF3000iSE
retired gadgetman
obgraham
And in addition this road has about the highest concentration of truck traffic of any in the US. (Perhaps that's why it's beat up?)
HappyKayakers
SPRING STREET wrote:
After the Scotsburg exit 29 it will get extremely rough and i mean rough in some sections.
That's the same section where I broke an axle hanger last year. Go slow!
Joe, Mary and Dakota, the wacko cat
Fulltiming since 2006
2006 Dodge 3500 QC CTD SRW Jacobs Exhaust brake
2017 Open Range 3X388RKS, side porch
SPRING_STREET
Nashville to Louisville is fine. Once you cross the bridge to Indiana there is construction for the new bridge that is being built but should not affect you on your northbound trip.After the Scotsburg exit 29 it will get extremely rough and i mean rough in some sections.
