โDec-10-2016 05:00 PM
โDec-12-2016 06:30 AM
โDec-12-2016 05:55 AM
Mr.Mark wrote:
Don't assume that ALL upper end coaches are rattle free. My test drive of a new Prevost Marathon was very 'under whelming'. On this brand new coach there was a rattle behind the driver area that was very distracting.
You would think that the salesman would have corrected any problem before a test drive. Also, Marathon uses a particular driver's seat that you have to 'lock down' or you are up and down like a 'jack-in-the-box'...which I was.
Finally, the sales person locked down the seat so that I could keep my feet on the pedals. It was not a good sales presentation.
There was another Prevost converter showing at the same RV resort. What a difference on presentation. First, our converter uses a totally air/electric driver's seat that does not move to extremes as it doesn't require to be 'locked-down
A high end coach presentation is very important.
MM.
โDec-11-2016 07:12 PM
โDec-11-2016 05:46 PM
โDec-11-2016 04:53 PM
โDec-11-2016 04:06 PM
praisetoGod wrote:univmd wrote:
City airport shuttle buses are rear engine diesels. Was it louder than a city bus?
I've never ridden on a city bus so I don't know. Sorry if I've confused anyone, but the noises that I heard weren't engine related. The engine was very quite. I just want few rattles and a solid frame.
I'm going to go back next week aftrr they've tightened down the panel to the left of the driver, and test drive it again on a different stretch of road.
โDec-11-2016 03:12 PM
โDec-11-2016 02:24 PM
We Cant Wait wrote:
As to the 3rd noise being frame noise I'd suspect that the dealer has the tire pressure set at the max. as shown on the side wall of the tire. Once you buy any unit get it weighed, then go to the tire makers chart for the appropriate air pressure i.e. our max tire pressure on the tire is 120psi, according to my weighs I run 100 in the front and 90 in the rears, this is according to the tire makers chart.
โDec-11-2016 01:42 PM
โDec-11-2016 01:34 PM
โDec-11-2016 01:16 PM
โDec-11-2016 01:11 PM
praisetoGod wrote:
We are looking at a Fleetwood Pace Arrow on a Freightliner chassis. One thing that really attracted us to this model is the drop down queen bed above the driver area. It has bunk beds too. We have 4 kids so it has enough sleeping space so that I can leave the dining table for dining, and the sofa for sitting, without having to pick up bedding. The drop down queen bed is motorized and has 4 chains, one on each corner. The chain is surrounded by a metal plate and on the bad road was vibrating against the metal casing. The dealer said there wasn't anything they could do about it, and suggested putting a piece of foam in it while traveling (there is in open slit in the middle of the metal casing exposing the chain).
The second noise was the console to the left of the driver where you shift from neutral to drive/reverse. They found something loose and said that can be tightened.
The third noise I'd say was the frame and that came on the hard bumps in the road. I test drove this on a super rough stretch of interstate and for this noise I'm guessing that was the problem.
My dad has a Fleetwood, and while I haven't ridden in his, I've heard that Fleetwood makes a quality product.
โDec-11-2016 01:00 PM
praisetoGod wrote:
The noises were rattles. No issues with noise from the diesel engine in back. I heard that motorhomes were slow to accelerate, but I was surprised by the amount of power.
โDec-11-2016 10:24 AM
Mondooker wrote:
Weight and wheelbase dictate ride and balance in any vehicle. Especially a large bodied product like a motorhome. The other component that settles things down even more is a Tag Axle, that that's an entire different story.
I drove a Thor Palazzo that had a loose dash and you'd start praying because with every bump you thought life as you know it was over! And the salesman knew it and still had me drive it without a word of caution. Strange!
โDec-11-2016 10:01 AM
