โMar-01-2014 04:56 AM
โMar-04-2014 04:45 AM
โMar-02-2014 09:53 AM
2006 Bounder 35E, W22
โMar-02-2014 09:32 AM
donandmax wrote:Might be some useful info in this current thread .
I would like to replace my interior lighting. Wedge type bulbs are in there now (12 volt of course) Wattage unknown.. What should I use to replace them with LED type.? Nice and bright..
โMar-02-2014 05:26 AM
RoyB wrote:
The rule of thumb for me was to get between 400-500 LUMENS per light fixture and most people like the WARM WHITE type LEDs that seem to look much like incandescent bulbs. Alot of folks will only buy one for the first install to make sure it is what they are expecting.
I dumped around $200 into my first go around and although the LED lights were great I had issues with RFI where the ones I got had built-in regulators on the LED BOARDS that would operate from a 6-20VDC DC source or something like that.
I first ended up with COMMAND ELECTRONICs PN 170-111 which are 510 LUMEN Boards that stick up inside the DUAL and SINGLE Ceiling light fixtures - They put off excellent light. For my other sockets Porch Light- a couple of Bed Area lights I used the LEDTRAILER ROUND LEDs PN 921-380 which are 380 LUMENS. They are excellant lights as well.
The RFI generated signals from the LED BOARD regulator chip circuit in my case would totally blank out my HDTV signals when I was using the OTA BATWING antenna to pick up the NATIONAL BROADCAST Digital TV signals from local towns. I also could not pick up the WX ALERT VHF Radio transmissions and my VHF/UHF Ham radio radios would not work.
Not saying this will happen to you but has happened to many others on here...
My way out was to use a LED LIGHT NON REGULATOR BOARD... I used the SMD BOARD 36-1210 type LED 252 LUMENS (Ebay from CHINA @ $4.99) that does not incorporate an ON-BOARD regulator that allows the board to operate between 8-30VDC using what is known as a BUCK REGULATOR circuit. I have tried a couple of these non-regulated boards and they work fine with NO RFI signals being produced. With my DC Voltage range of 13.2 to 14.4VDC they seem to work just fine but the experts tell me their life span may be reduced somewhat as their operating voltage range spec is not that high but at $4.99 each probably no big deal. I do have a couple of the china boards with a few group of three LEDS lights not burning. When it gets too bad to see then I will just replace the board with another $4.99 board. I purchased 10 spares of these boards and still have ten spares left after four years of use.
Since I have the DUAL Ceiling light fixtures that turned on both sides at same time I had to modify my old fixtures to a three way switch version models which allows me to turn on one side or the other or off. I have the American brands with regulators in one side and the China brand without regulators in the other. This way I can switch to the NON RFI type boards when camping off the power grid. Seems to work out pretty good for me doing it this way. Keep in mind all of my incandescent light bulbs are the 921 wedge type... Like said above just order ONE to try out and not get a whole a set for around $200... They might not be what you expect...
None of the 15-50 Lumen size LEDs worked for me - even in the bed room directed swivel lights... Way too dim... Changing to LEDs really worked great for us camping off the power grid and they dont get any where near as hot as the incandescent bulbs. Try grabing the old style after it has been on for 10-minutes. My old bulbs had already started burning the plastic holders and turning them brown. I also didnt get the LED diffusers with the first round of LEDs. One of those companies I listed has the replacement diffusers lens available which really make a big difference. This spreads the LEDs light beams out better then the original light assy has in them. I am still using these boards today for the past 4 years now.
Good luck...
Just passing along for your info only - The thing learned for me was only BUY ONE and try it out. If it is too YOUR liking then buy the rest of them...
I'm sure you will hear both sides to this story... I got the same results from my 2008 OFF-RoAD POPUP trailer as well as my 2005 Fifth wheel trailer using the REGULATED TYPE LED BOARDS.
Just BUY ONE to try it out...
My LED REPLACEMENT STORY
Roy Ken
โMar-01-2014 08:48 AM
Jayco23FB wrote:
Go to superbrightleds.com they have a great site.
โMar-01-2014 06:51 AM
โMar-01-2014 06:45 AM
โMar-01-2014 06:06 AM
โMar-01-2014 05:30 AM
