Kwikee series 32
Stingme62
I have searched everything on this so I'm praying someone out there knows what I'm talking about.
According to my sticker, I have a Kwikee series 32 steps. I've worked on this before where the unit has fallen out. However in this one case, the unit fell out and a very specific sprocket was lost. It actually fits over the main sprocket on the motor. After this spocket that fits over the motor spocket also as a pin that fits into the gearbox.
Does anyone know what I'm talking about? I can not find this lone sprocket.
Thanks
11 REPLIES 11
garry1p
I repaired mine without removing a heck of a lot easier if you can work on your back. I did drop the gear but thankfully I found it.
Call around these people get smashed up steps and might have the parts.
salvage parts
Garry1p
1990 Holiday Rambler Aluma Lite XL
454 on P-30 Chassis
1999 Jeep Cherokee sport
Executive45
dougrainer
Chum lee wrote:
dougrainer wrote:
Tyldon wrote:
The gear ad shaft is available from Lippert the maker of the steps. If you lost the gear totally first is the gear just stripped? If the gear is gone the ay other parts are missing. If like mine the gear was stripped ( donโ€™t let ,kids ride the steps)
To replace the gear I have found it better to remove the entire step assembly from the mh. Make sure to note the position of the gear
You obviously do not have a Kwikee step but a LCI Coach Step. There is NOTHING on a Kwikee series 32 that would require removing the step. Even the LCI Coach Step, you do not have to remove the step to replace the parts. Doug
I disagree with this. I have replaced the Series 32 step motor/gear drive on my 1999 Class A F53. The fasteners holding the gear box to the step frame were rusted and stripped out requiring that I remove the step mounting frame which also had rusted attaching bolts which stripped out of the coach mounting frame captive nuts. I cleaned (derusted) and powder coated the steps and mounting frame prior to reassembly using a new fasteners and a new gear drive and motor.(updated design) In theory, I shouldn't have had to do what I did, but that wasn't reality in my case. The large gear inside the drive box exploded in my case. I was unable to locate new drive gears separately so I just bought a new gearbox/motor assembly. ($250.00 in 2013) It works fine now. IMO, the old motor/gearbox was a POS. IMO, regular dirt/water spray from the right front wheel/tire doesn't help the assembly.
Chum lee
I have probably replaced MORE kwikee gear housing in the past 5 years than anybody on these forums and have never had to drop the step. The 4 bolts that hold the gear box are Carriage bolts. You just slightly loosen the 4 step mount bolts to let the step hang a little and install the 4 new carriage bolts. Now, if the step needed rust clean up and paint, then removing is the way to go. BTW, those 4 Carriage bolts come with the new Gear Box housing. Doug
PS, The most common cause of failure(motor or gear linkage assbly) of a Kwikee step is lack of cleaning(dirt/mud removal and lubing the pivot/linkage points. This is explained in the Kwikee owners manual, which nobody reads, then they blame Kwikee.
Chum_lee
Chum lee
dougrainer
mike brez wrote:
Maybe here
Look at Page 70. It shows the motor with the gear and pin below the motor. THOSE parts are not available. You have to purchase the complete gear Box assbly if you lose the gear and pin. Doug
dougrainer
Tyldon
wa8yxm
way2roll wrote:
You mention that the unit has "fallen out" several times. Do you mean the entire step motor assembly? Why would this happen? If it were me I would solve the root of the problem and replace with a new unit. Sounds like the individual gears aren't available anyway.
I wondered about that too. There is only ONE TIME anything ever "Fell out" on my steps..
It is my belief that Kwikee uses "2nds" for the motor. the motors often have a "Dead spot" and if it stops on a dead spot. the steps won't work.. Tapping motor with hammer (handle end) moves it just off the dead spot and steps work again.. next page
So I opened the transmission (After spreading a tarp below it to catch anything that fell) and "re-indexed" the motor so it stopped at a different spot (Sounds hard but it simply means when I opened the tranny and removed the gear the steps retracted half way. I put the gear back and that's that) .
But with the tranny closed up (Screws in place) NO WAY can anything fall save the entire step assembly.. And I fixed that too.
way2roll
Navigator
Navigator
Jeff - 2023 FR Sunseeker 2400B MBS
dougrainer
That part is not available separately. Doug
mike_brez
Maybe here
1998 36 foot Country Coach Magna #5499 Single slide
Gillig chassis with a series 40
02 Ford F250 7.3 with a few mods
2015 Wrangler JKU
