Nov-01-2016 10:57 AM
Nov-05-2016 05:46 PM
Nov-05-2016 04:27 PM
steppinstone wrote:No. What I see is a large difference in your high and low numbers which were all done under the SAME conditions. If a warm or cold engine would change the numbers it would change them all, not just part of them. You have numbers all over the place which tells me that you probably have some valves with variable amounts of burning so it is time to redo the top end before that causes more issues. If a couple of cylinders are not putting out their share it means the others have work harder and performance and mileage go down and wear factors increase.
When I took the reading's the engine was cold will that give a bad reading? Just curious?
Nov-05-2016 08:33 AM
Nov-05-2016 07:41 AM
Nov-04-2016 11:05 PM
Nov-04-2016 08:22 PM
Nov-04-2016 07:42 PM
Nov-04-2016 07:36 PM
Nov-04-2016 06:24 PM
Nov-04-2016 05:21 PM
Nov-04-2016 02:09 PM
Nov-04-2016 01:27 PM
Nov-03-2016 12:01 PM
Nov-03-2016 09:35 AM
