Dec-30-2017 07:39 PM
Dec-31-2017 04:42 PM
blknomad wrote:
also the op mentioned a "Columbus" I give up??
Dec-31-2017 04:25 PM
Dec-31-2017 04:22 PM
Dec-31-2017 04:20 PM
Pirate wrote:pianotuna wrote:I've seen you post this a couple times. I just don't understand what is the purpose of the fans. Can you explain further? Tks.
For truly cold weather when using electric heaters, consider replacing the return air grill for the furnace with twin window fans:
Dec-31-2017 03:15 PM
Dec-31-2017 02:29 PM
Dec-31-2017 02:23 PM
GordonThree wrote:
Only a small amount of offense intended... I really get a chuckle out of below freezing being considered extreme cold.
My personal scale puts extreme below the -20F mark. Above that through zero is very cold, 0 to 20 moderately cold...
Dec-31-2017 02:13 PM
Bill.Satellite wrote:gsf35099 wrote:
We really are doing great and I wasn't sure what to expect.
It's 16 degrees this morning and the furnace has been set at 64 and cuts off when it warms up. :). Furnace doesn't stay off long, seeing ~9-10min cycles off, & 4 min on. We had it on 68, but that was to warm for us. should have known since 62 is what we sleep in back home. Haha
I had engineered hardwood floors installed ~ 1 1/2 years ago and they stay pretty warm as well. Ducting is in the floor. I did bring 2 sleeping bags and used them to fill the gap under the large slide in the living room and appear to have no draft from under the slide. We have a few rugs, but again, the floor is not really cold. Coldest place seems to be back of RV passenger side floor where our small slide is, buts it's not freezing, just colder then most and I notice it since that's my side and where I place my bare feet in the morning getting up. :). Still not bad though.
Overall, I'm very happy with how the RV is handling the cold. We've already been through a low of 15, high of 28 last Thursday and I'm not concerned about the next 3-4 days of highs in the 20's & lows ~10. Got plenty of propane to make it until we head out Wednesday as I topped off last Friday heading into the long weekend.
Stay warm and Happy New Year!!
Just be sure to keep an eye on your propane level. You are toasty due to a very inefficient furnace when it comes to fuel usage. The propane will not last for weeks so just keep an eye on it and be prepared to go get more if necessary.
Dec-31-2017 01:40 PM
Dec-31-2017 09:48 AM
Dec-31-2017 09:47 AM
Dec-31-2017 09:28 AM
Dec-31-2017 07:32 AM
Dec-31-2017 07:01 AM
