Apr-26-2019 10:18 AM
Apr-27-2019 01:50 PM
Executive wrote:
Looks like a previous owner "borrowed" that relay earlier. 🙂 Glad it was an easy, and inexpensive fix. I hope you replaced the one you borrowed this one from....Dennis
Apr-27-2019 08:55 AM
Apr-27-2019 07:50 AM
Apr-26-2019 07:22 PM
Apr-26-2019 04:41 PM
Apr-26-2019 03:42 PM
JaxDad wrote:
With a lot of Ford chassis’ the marker lights are on the same circuit as the trailer lights.
This so that, in the case of a dually for instance where you can’t always see the trailer behind the wider fenders, you see that your fender markers are out and know your trailer is out too.
If your unit is on a Ford commercial chassis check the trailer fuses.
Apr-26-2019 02:35 PM
Apr-26-2019 02:33 PM
Apr-26-2019 02:01 PM
sealevel ram wrote:
I have a Winnie 04 Ultimate Freedom, which I have driven on several trips for several years.
Just decided to check all my chassis lights, and find out that my marker lights don't light. I am assuming that they come on when the headlights are activated.
I am also assuming this is the name for the lights on the very top in front and on the spoiler in the rear. Never really checked them before.
Checked all fuses, OK.
There is a relay space on the fuse panel labeled "MRKR LTS", which does NOT have a relay in it. The space above this one ("DRLM") has a relay that looks like it might fit, but I am afraid to try it.
The only thing that I have changed regarding lighting was to put in a new Smart Wheel controller package a couple of years ago.
Some of you smart guys or girls probably are experts on this.
Thanks for the help.
