Oct-28-2019 04:01 AM
Oct-30-2019 05:34 AM
Oct-29-2019 03:56 AM
Oct-28-2019 07:43 PM
Oct-28-2019 08:22 AM
Oct-28-2019 08:19 AM
DrewE wrote:. You are correct DrewE. The GAWR is only 9450. I grabbed the wrong one when I was typing. Thanks for your help. That took a load off my mind that I’m good to go on towing my car.
With a tow dolly, the tongue weight (which, as DaButcher observes, is the "Max Vertical Hitch Load") is quite low. It sounds like you'll be good to go.
Incidentally, I believe you have a typo in your rear axle GAWR in the post; it looks suspiciously like the GVWR. I think it's actually 9600 pounds; but that doesn't change anything for being able to tow your Fit with this setup and equipment.
Oct-28-2019 05:55 AM
Oct-28-2019 04:19 AM
