Motorized Carefree awning - one arm sagging
csltbr
Hi,
One arm of my motorized Carefree awning would not fully extend - maybe by and the awning is sagging
https://photos.app.goo.gl/StDkRNjqfoXHcVtT9
The other arm has no problem at all.
I have no problem retracting it.
Looks like the motor is ok. Is the problem in the arm? how do I fix it? anywhere in the arm I can adjust the arm?(can not find anything obvious by looking outside.
Please advise.
Thank you in advance.
6 REPLIES 6
csltbr
Understood.
Thanks for the reminder.
dougrainer wrote:
Be VERY careful. It is not as easy at it seems/looks. Doug
It is amazing how much force those shocks have
dougrainer
csltbr
No by design, worked perfectly until last week...
wa8yxm wrote:
That may have been done on purpose... So that if it rains water runs off easier.
Or not.. Not a Carefree expert by any means.
wa8yxm
Lwiddis
And lubricate IMO.
csltbr
Just figured it out myself, the gas spring on sagging side is not extended to its fully length, it is 2.5" shorter than the other side.
Just need to change the gas spring, that should fix the problem.
