Oil change at Camper World
DanLefoot
Hi folks.
I normally use RV Specialists in San Diego for service on our Monaco DP.
They charge about $600 for an oil change and lube. Includes a general inspection of the motorhome, including belts, hoses and brakes. ( without removing tires) included in the charge is $240 for labor. Does not include fuel filters.
Camper World does an oil change and lube for $169.
What says you?
Dan
23 REPLIES 23
bluwtr49
You might try Cummins Pacific or Hawthorne Power System.
Dick
2002 43' DP Beaver Marquis Emerald Cat C-12 505 HP, 1600 Tq
2003 Jeep Grand Cherokee Overland ---toad
Bird_Freak
DanLefoot wrote:
Bird Freak wrote:
Camper World or Camping World? If Camping World I would never let them do anything mechanical to my coach.
Sorry. camping World.
How can you screw up an oil dump, filter change and oil refill?
Dan
Very easy, stripped or loose oil plugs that would leak or come out, Wrong oil, too much oil blowing seals, not enough blowing engine. Do you want to take the chance of replacing your engine. Take it to someone that knows engines not someone who mainly works on the house section.
Eddie
03 Fleetwood Pride, 36-5L
04 Ford F-250 Superduty
15K Pullrite Superglide
Old coach 04 Pace Arrow 37C with brakes sometimes.
Owner- The Toy Shop-
Auto Restoration and Customs 32 years. Retired by a stroke!
We love 56 T-Birds
BigSkyBob
I've had the same diesel repair shop service my coach since new. 26 quars of Rotella 15/40, Fleetguard filer and COMPLETE chassis lube for $225 out the door. The service before that was $260 but when the oil market tanked they dropped the tab to $225. They never missed the drive line, U joints and slack adjusters.
2008 Monaco Camelot 40PDQ, 4 slides, 2016 Dodge Ram 1500 Hemi Quadcab 4x4. Blue Ox, Garmin 760 LRM GPS, Doran Pressure pro on all 10, M&G Brake, 50 amp SurgeGuard, FMCA, Coachnet.
sdianel_-acct_c
We stop at Speedco during our travels. No appointment necessary. Takes about and hour. There are none in Florida but we stop at the one in Georgia on our way out of state.
We also use Cummins Coach Care for other maintenance and repairs. If you have a Cummins engine, be sure to join the Cummins Power Club for 10% off.
Lonny & Diane
2004 Country Coach Allure 33' "Big Blue"
Towing 2008 Chev Colorado 4x4
Semper Fi
crasster
Always watch out for cheap oil and filters.... $600 seems steep though. What type of oil and filter is used at camping world? Also do they check anything else?
4 whopping cylinders on Toyota RV's. Talk about great getting good MPG. Also I have a very light foot on the pedal. I followed some MPG advice on Livingpress.com and I now get 22 MPG! Not bad for a home on wheels.
wa8yxm
I know on my Gasser CW not only charged more than the Workhorse Authorized Service Center by nearly 50 percent.. I specified synthetic oil and they put in regular dino.
No further comment.
JumboJet
Self Service for my Ford V-10:
7 quarts Mobil 1 Synthethic x $6.50 = $ 45.50
1 Motorcraft oil filter $ 4.40
1 Motorcraft fuel filter $ 14.75
1 Tube Chassis grease $ 5.00
Total $ 69.65
Shop building $35,000
Tools $20,000
20 point checkup - 1-2 hours of labor
My RAM 3500 is about 3X that cost. Fuel filters alone are $110.
smlranger
As noted, would not let CW change oil in my lawn mower. I've used Speedco and they were fine. Now using my local Cummins Coach Care. Oil, filter, chassis lube, fuel filters just a tad over $200.
Went to local CW few years ago to get a new awning installed on previous coach. They installed the awning wrong and had to take it back to have it fixed. They trashed the fabric and had to order new fabric. When I got the coach back, the service advisor proudly told me 'their top technican' discovered that my tires were low and took care of it. I asked him what he found and he said your fronts were at 105 an rears at 90, so he put them all at 120. When I told him my pressures were correct based on actual four corner weights and the manufacture's load/inflation tables, he looked at me like I had three heads. They had no clue what I was talking about.
Never again, sorry.
2019 Grand Design Solitude 384GK 5th wheel. Glen Allen, VA
Phil___Stephie
Another vote for SpeedCo. Been using them for several years, pleased with their service. Mine, for 23 quarts runs around $225.
Phil & Stephanie Grey
"Partners In Life"
2016 Allegro 36LA
2007 Chevy HHR
Yorkies; Paisley Marie & Opie Taylor
fla-gypsy
$600 is robbery, $169 is a pipe dream. You need to find a new source for this service.
ArchHoagland
Executive wrote:
OP....two words...."ROAD TRIP"..!!!.....:B:B....Dennis
I agree with Dennis...Think I'd check around and do a trip somewhere that you can find a decent price and a few recommendations from people who have used the facility.
$600 seems a bit steep.
2004 Monaco La Palma 36DBD
Workhorse W22 8.1 Gas Allison 1000, 7.1 mpg
2000 LEXUS RX300 FWD 22MPG 4020 LBS
US Gear Brakes
Executive45
darsben
Dan
they are professionals so they will figure a way.
If u do go to CW get an out the door price BEFORE starting the job
Traveling with my best friend my wife!
DanLefoot
Dan
