Usagi
Sep 15, 2013Explorer
Onan flooding and engine does not charge house battery
I have a 1994 Four Winds 5000 R/V that I recently bought. It's 29 ft in length.
The Onan 4000 generator is hard to start. I believe it's flooding. There is a strong smell of gasoline while it is cranking. Is there some trick to starting it?
Charging:
There is a LED charge indicator on the wall. With nothing running, the yellow LED is lit. With the generator running the green one above it is lit. With the R/V truck engine running the yellow LED is lit, which I believe is indicating that the engine is not charging the house battery. Is there a switch, solenoid or breaker that needs to be thrown for the house battery to charge? If so, where do I find it?
Charging:
