โJan-01-2016 09:19 PM
โJan-10-2016 08:24 AM
โJan-09-2016 05:11 PM
โJan-09-2016 03:46 PM
โJan-09-2016 03:26 PM
โJan-09-2016 07:43 AM
Ed_Gee wrote:wolfe10 wrote:Ed_Gee wrote:enblethen wrote:
Many rigs have detachable shore power cords.
Detachable power cord
Yes, 5th wheels do. The original poster has a Class A motor home. Those do NOT have detachable power cables.
Actually, some motorhomes DO have detachable shore power cords.
I am curious what class A motor home has a factory detachable power cord. I have never seen one - and I have seen thousands. Then again, I'm not referring to decades old motor homes, either.
โJan-09-2016 07:38 AM
โJan-03-2016 12:59 PM
enblethen wrote:X2
I would check your power readings either in the coach with all breakers turned off, or at the rig end of shore power cable.
Sure sounds like a neutral problem.
โJan-03-2016 12:23 PM
Bud
USAF Retired
Pace Arrow
โJan-03-2016 12:14 PM
enblethen wrote:
J6 is the power to the shedding relays, in and out.
J3 appears to be the current sensor.
On the attached electrical drawing I do not see any connection to the circuit board(EMS)
โJan-03-2016 11:04 AM
Bud
USAF Retired
Pace Arrow
โJan-03-2016 10:57 AM
enblethen wrote:From that manual I believe you are misinterpreting the information. To me a Line 1 breaker does not mean the 50A breaker. From my experience it's a 20A breaker that feeds the relay for load shedding and for 240V detection. J1 and J3 are used for 240V detection and for 2 20A load shedding appliances.
On the attached electrical drawing I do not see any connection to the circuit board(EMS) to any breakers.
Here is manual for the 900
900 Manual
To insure proper operation of the source sensing circuitry on the 50 AMP EMS Model 700, jumper wires must always be connected from a Line 1 breaker to J6 terminal 3, and from a Line 2 breaker to J6 terminal 1. These connections must be made even though Relay 1 or Relay 2 may not be used for controlled loads.
J6 terminals
1 From Circuit Breaker for Relay 2 ( )
2 Output of Relay 2
3 From Circuit Breaker for Relay 1 ( ) 1 From Circuit Breaker for Relay 2 ( )
4 Output of Relay 1
โJan-03-2016 10:32 AM
Bud
USAF Retired
Pace Arrow
โJan-03-2016 10:19 AM
CatchinBluegill wrote:
Honest question: why _wouldn't_ a coach vendor put on a detachable cable? That makes it easier to replace the cable if necessary.
โJan-03-2016 10:08 AM
